メインコンテンツにスキップ
iPhoneの5代目となるiPhone 4S。このデバイスの修理は比較的簡単で、スクリュードライバー、開口ツールと忍耐が必要です。GSM/CDMA / 16, 32, 64 GB / 白と黒
2201回答 すべてを表示
締切られた回答
Is it possible to upgrade from 512 MB to 1GB of ram?
Would it be possible to upgrade the 4S ram by swapping chips? Is there even a compatible 1GB chip available? Do you think the hardware would then recognize a bigger chip or would it cause problems?
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 3
2 件のコメント
If your asking, then you probably can't and shouldn't do it.
さんによる
It is a good question, but not possible:-)
さんによる
コメントを追加
3件の回答
ベストアンサー
Unfortunately, the RAM is integrated into the logic board, so upgrading the RAM would be extremely difficult if not impossible.
このアンサーは役に立ちましたか?
スコア 6
3 件のコメント:
Yeah, I know about it being part of the logic board, but I was just wondering if it would be possible if one was super careful with soldering (i.e. using a microscope) if the contact arrangement was the same.
さんによる
"super careful" ? - are you aware that you have to solder stuff like that with infrared- or hot-air soldering stations????
さんによる
Just check on here http://www.circuitrework.com/guides/7-0.... and see what you think. with a medium grade station like this http://www.hakkousa.com/detail.asp?CID=5... and lots of practice , it might be possible. Oh yes, where are you going to get the the RAM from?The IC on the logic board for the 4s might not fit the 4 circuit board. So you will also need the datasheets for both of the IC's to make sure that the internal 'layout' is the same. You see, to many economical and logistics head aches to even try for one phone...so go with what Matt and markus are saying.....;-)
さんによる
コメントを追加
Upgrading RAM is not possible on the 4S, even with a rework station and the knowlage to use it. The phone's RAM is embedded in the A5 "System on a Chip" CPU, It is not on it's own individual chip. This makes upgrading RAM inpossible.
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
My touch screen has a semi flex - broken. If the phone is switched on without connected touch flex and then i punch my phone to reconnect the flex, my phone recognizes it and makes it work .
therefore means that android somehow works with a " plug and play" system
That would mean that if I change the ram chip , it can recognize up to where the chip responsible for administering the ram can handle it
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
I do not follow you are all. Are you talking about an iPhone? Are you talking about memory that is plug and play? Do you realize how the memory is installed on the logic board?
さんによる
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 1
今までの合計 4,088
