メインコンテンツにスキップ
2017年11月4日発売。モデルA1865、A1901。GSMまたはCDMA/64GBまたは256GB/シルバーまたはスペースグレイ。(発音は「iPhone 10」と同じ)。
1199回答 すべてを表示
Water damaged iPhone X 4013 error
Hi Guys,
I have an iphone x with severe water damage. I can turn the iphone on and put it in recovery mode. I tried to restore it with Itunes, but i get an 4013 error. I searched alot on google and found out that error 4013 could turn op while restoring by water damage in the FaceID / earpiece connector. I tried disconnecting al flex cables including the FaceID one, still wont restore in Itunes. I disconnected the cameras and all other cables but the Iphone still cant restore. Does anyone know what i can try next? I can solder by myself but solder the motherboard is to next-level for me. Any tips?
Thanks.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
ベストアンサー
Error 4013 can be a number of things especially if it has had liquid damage. You would need to split the board and check for liquid and clean with a ultrasonic cleaner or Isopropyl alcohol. You would than need to resolder the board back together and preferably check by putting it in a known good OEM housing.
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
回答を追加する
Niels Martens さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 9
過去 30 日: 30
今までの合計 2,745
