メインコンテンツにスキップ
2016年9月16日に発売。モデル番号は1660, 1778で GSM かCDMA があり。/ 32、128、 256 GB / 色はローズゴールド、ゴールド、シルバー、ブラック、ジェットブラック
2264回答 すべてを表示
Overheating NAND in iPhone 7
I have an iPhone 7 which came to me looking like it was thrown against a brick wall but the board looked good. Power is coming in fine, but amperage is constantly rising to 480 milliamps and dropping, over and over. With freeze spray, I found that it's heating REALLY rapidly under the CPU where pins c65/c66/d66 are (pp1v8_sdram and pp1v1_sdram). Can someone throw me a bone? I've checked for shorts at every point that these pins are related to. Can someone help me get on track?
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
2件の回答
ベストアンサー
You need to determine if it is a power issue or a data issue. A close visual exam is also extremely important. You said it looked like it had been thrown against a wall.
·         The .48A is coming from your DCPS and not an amp meter?
·         Check all NAND power rails are producing the correct voltage.
·         Check all coils around CPU for cracks as this happens on the 7 series.
·         Try putting it in DFU mode.
·         Put some pressure on the CPU and prompt to boot.
These can turn into time consuming repairs but as I said you first need to determine if it is a data problem or power problem.
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
Have you attempted a battery replacement? Also, is the battery 3rd party or does it have low health?
このアンサーは役に立ちましたか?
スコア 0
2 件のコメント:
Based on description, it's never about the battery.
さんによる
The battery has been checked/swapped twice.
さんによる
コメントを追加
回答を追加する
Sarah Wreisner さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 1
今までの合計 112
