メインコンテンツにスキップ
Model番号 A1225 / Mid 2007とEarly 2008 / 2.4, 2.8もしくは3.06 GHz Core 2 Duoプロセッサ
435回答 すべてを表示
The memory I purchased does not work very well.
The memory I purchased does not work very good. Neither one works alone or in tandem. The only way they work is if I use one of them with the Apple memory that came with the iMac in one of the slots. I mixed and matched several times so it’s not like I’m seating them incorrectly.
So instead of 4gig with the two I bought, I can only get 3gig.
Thank you
John Coffey
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
Depending on your exact model as well as your OS-X version 3 GB maybe the limit!
The White iMac’s need to be running the OS X 10.7.5 and you needed a firmare update. Its been awhile and I don’t know which one was the needed version.
Locate your exact system here EveryMac - Lookup plugging in your systems S/N. Then tell us which is yours.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
SV In Like Flynn さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 8
過去 30 日: 12
今までの合計 49
