メインコンテンツにスキップ
2017年6月発売。このiPad Pro 10.5インチモデルは2016年に発売されたiPad Pro 9.7インチモデルのアップグレード版です。
145回答 すべてを表示
Boot Loop, Red Screen, starts and crashes.
Hi guys! I need help!
My ipad was working perfectly fine until it wasn’t. The apple logo has been stuck on a loop for days, cutting on and off. My screen is cracked. I attempted to put it in restore mode (which works for a second) - I update the the ipad and then it crashes after updating and goes BACK into logo loop.
I took it to the store to see what they say, and they are saying that they’d have to open it up and they are charging me about 300 total…. (50 to open it up, and the rest to fix the problem)
they said I might as well but a NEW IPAD at this point.
PLEASE I NEED OPINIONS!
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
hello Azizah,
unfortunately, they are right. Repair of iPad is unprofitable because, not many technicians have enough knowledge to it. Technical documentation is residual. But, if you a familiar with electronics, you can repair it yourself. It is not a very complicated.
Many of iPad faults is related to falls and power problems (non-genuine cables and chargers). Unfortunately, opening of device is nesesery that is neither easy nor safety. Many screens are damaged on this stage (that is 50$ for opening :-), by the way - that is quite cheap, mostly is 75-100$). In my opinion (based on hundreds of repairs iPads in my career) you have got problem with power consumption. It is required to connect the meter and check the current consumption during start-up. Based on this, appropriate conclusions can be drawn.
Similar faults cost 200 $ plus about 75% for opening and closing the device (if the screen is not cracked. If it is - 200-250 $ extra for a new screen). As you can see, maybe you should consider sell your iPad (for $) and buying a new one (up to 400$).
  • regards
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Azizah さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 10
今までの合計 191
