What should be replaced from the picture.
Hi,
other than a screen, is there anything else from the picture that you can tell needs to be replaced?
thank you!!
この質問は役に立ちましたか?
Hi,
thank you!!
この質問は役に立ちましたか?
hello Nelk,
It looks like the front cam assembly is damaged. Need a test. The front camera is a set of several elements: a front camera (selfie camera), a proximity sensor, an ambient light sensor and ear speaker. Everything fastened on one flex. Quite cheap and easy to install.
このアンサーは役に立ちましたか?
Thank you so much for you input.
The earpiece is a separate part that has a contact to the sensor ribbon. However, chances are that doesn't need replacing.
過去 24時間: 0
過去 7 日: 0
過去 30 日: 1
今までの合計 31
