メインコンテンツにスキップ
A mid-range smartphone from Samsung released in 2019.
118回答 すべてを表示
Will device boot with no battery?
Hey, i was taking a look at a phone for someone who said it wont charge or turn on.
When plugged in a lighting bolt in a circle appears but no battery percentage. i took apart the phone and disconnected the battery then plugged in the charger and same thing
Lighting bolt in a circle with no battery percentage
Does this mean the battery is the problem? The device in theory should boot without one while plugged in like a laptop.
Would this mean the issue is software and not hardware since the charging port is working.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
3件の回答
最も参考になった回答
Austin Sidman this “ i took apart the phone and disconnected the battery then plugged in the charger and same thing. Lighting bolt in a circle with no battery percentage” makes the battery the prime suspect. Replace the battery then re-evaluate. There are multiple other board level hardware issues that could cause this but start in an orderly fashion so as to not try to change/repair parts that don’t need to be replaced/fixed.
Samsung Galaxy A50 Battery Replacement
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
It could be software related, but to me it rather sounds like a problem with the part of the circuit that charges the phone (or the battery itself).
It is with some phones possible to boot without a battery depending on the amount of power the phone consumes, and the chargers ability to provide this power.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
it can work with some devices or with some ways for example with USB, sun energy, or you can use it when you power off it
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Austin Sidman さん、ありがとうございました!
統計データ:
過去 24時間: 4
過去 7 日: 13
過去 30 日: 46
今までの合計 1,458
