メインコンテンツにスキップ
2017年Appleは13インチMacBook Airに新Broadwell Intl Core i5プロセッサを搭載して登場させました。バッテリー寿命の改善とパフォーマンスがわずかに向上しました。
20回答 すべてを表示
Keyboard replacement on MacBook Air 13"
I have a MacBook air 13’’, Is there a way to replace the keyboard without having to replace the whole lower case? If so can you please direct me how to do so?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
It comes down to difficulty, time and costs!
If you’ve never replaced a Mac keyboard, you will likely prefer to replace the upper case which is the easiest way MacBook Air 13" (Mid 2013-2017) Upper Case with Keyboard at $110 USD its not a bad deal! It takes about 45 min’s to switch the upper cases out.
If you’ve done a few keyboards or just want to give it a try you can just replace the keyboard alone. But I’ll warn you its not easy and you may not like the condition afterwards. MacBook Air A1369 or A1466 keyboard for $30 USD. But the hard part is getting the rivets out and then replacing them screws (50+) doing all of that without bending the upper case and the frame. It takes a good two hours of time for me to do one, it will likely take more time if you haven’t done it before.
In either case you’ll need to follow this guide to get all of the parts out MacBook Air 13インチ Early 2017 上部ケースの交換
Replace an upper case and keyboard compatible with the Mid 2013 to 2017 model A1466 MacBook Air 13 inch laptop. Includes the keyboard, palm rest area, and power button. Part #661-7480.の画像
製品
$89.99
このアンサーは役に立ちましたか?
スコア 0
2 件のコメント:
It is worth nothing that if you decide to replace only the keyboard and not the entire upper case (including the keyboard) the process is even more difficult and rather messy. iFixit does not seem to have a guide on removing the keyboard, I used this video instead: https://www.youtube.com/watch?v=1qOaJ5S7...
Had I known this in advance, I would have bought the entire upper case.
さんによる
Thanks Marci, this is hugely helpful *****
さんによる
コメントを追加
回答を追加する
Clayton Mazuch さん、ありがとうございました!
統計データ:
過去 24時間: 14
過去 7 日: 104
過去 30 日: 364
今までの合計 7,243
