メインコンテンツにスキップ
モデル番号A1707。 2017年6月に発売されたこのMacBook Proは、最大3.8 GHzのTurbo Boost搭載の最大2.8 GHzクアッドコアIntel Core i7プロセッサーまでのKaby Lakeプロセッサーを搭載しています。
327回答 すべてを表示
Bootloop after Install Mojave, cannot Recovery or anything
Hello and I ask for help,
MBP 15” touchbar 2017, in normal use with Sierra, update to 10.14.6, after a week normal use and when to sleep, it turn off and got in to bootloop, I even tried do something but cant help:
- Bootloop at normal startup or auto turn off at process startup bar.
- Bootloop at recovery mode, internet recovery, shift mode (or auto turn off)
- Same as Mojave usb installer
- Same as Time machine backup from external drive.
- Sierra usb installer show as Folder and emty logo when chose, then turn off.
- Catallia usb installer show “You compurter restart because of a problem…” with many language.
- Use D, it runs fast (i dont think it took 3mins, just about 10–15secs) and show that No problem.
- Use CMD+S, as this picture, I think there something happened with system drive.
- Reset vram, pram… no help
Hope for help.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
2 件のコメント
Did you buy this as a new system or was it bought used?
さんによる
@danj I bought it 3 years ago as new with Sierra OS installed.
さんによる
コメントを追加
2件の回答
ベストアンサー
It sounds like the logic board has failed. I was thinking this was a bricked system as it does appear the logic board has been iCloud locked.
Best to get your system to an Apple Store for them to fix this.
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
Seem it must be serious!
さんによる
コメントを追加
timestamp indicate it need to reset the clock appropriately, if you are able to go to the BIOS (f1, f10) and reset the time zone, it may resolve the problem, it is recommended that you find someone who can help you using the BIOS configuration. That is a sensitive area of the computer, needs an experienced IT.
このアンサーは役に立ちましたか?
スコア 0
2 件のコメント:
Thank you for your infomation, let me check it out
さんによる
As I researched, macbook doesnt have BIOS, right?
さんによる
コメントを追加
回答を追加する
NiNi72 さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 2
過去 30 日: 5
今までの合計 83
