How can I connect my Atari 2600 to my TV?
Hello,
I want to connect it with my TV, but if I search manuel, there is just a black screen.
Can you help me?
Sincerely
Julian
この質問は役に立ちましたか?
Hello,
Can you help me?
Sincerely
Julian
この質問は役に立ちましたか?
Try connecting the Atari to an old analogue VCR’s RF input and have the VCR connected to the TV via a Component or Composite video cable connection
Switch the TV to the appropriate input and tune the VCR to CH2 or 3 (or 3 or 4) coming from the console
Most digital TVs can scan for the analogue TV signals output from the console but the resolution at 240p may not be accepted by the TV. (Atari is not shown in the list in the link but because it is also 240p it may be the same as the others)
このアンサーは役に立ちましたか?
Hello,
I have a Atari 2600 Light Sixer. I come from Germany. If I search for a Channel and choose wire, ATV and click on start, then it won´t find.
I did it with Channel A and B, but both didn´t work.
I don´t know what I should do.
Sincerely
Julian
@superjulianbros Did you try as suggested with a VCR (video cassette recorder) in between the Atari and the TV?
As I said the TV won't be able to recognize the signal from the Atari.
Hello,
I thank you so much. Can you send me a link for a VCR. I don´t know how I should search for it.
Sincerely
Julian
Here is a link that may hopefully help you. Scroll down to find "video rekorders". Maybe the older the better as the older ones were used with analogue TV signals and not digital TV signals
Perhaps you know someone who already has one and doesn't use it or look on other websites selling used equipment this maybe I don't know what is the best where you are.
Also maybe charity shops that sell 2nd hand goods etc.
You don't need one that plays tapes you're just using it to see if it can covert the Atari RF signal into a video signal (AV or Component) that the TV can understand, so the cheaper it is the better as you don't know that it will even work until you try it.
Good luck
Hello,
can I just buy the thing that change from RF to COAX?
Or have I to buy a video rekorder?
Sincerely
Julian
過去 24時間: 0
過去 7 日: 3
過去 30 日: 12
今までの合計 1,404
