メインコンテンツにスキップ
2018年7月に発売された15インチMacBook Proです。モデル番号はA1989です。15.4インチ LED-Backlightディスプレイ、True Toneテクノロジ、TouchIDと最大6 Core i9プロセッサを搭載しています。
205回答 すべてを表示
Issues after replacing swollen battery
Hi!
I recently replaced swollen battery on my 2018 15” MacBook Pro. After replacement there is a problem, sometimes charging adapter is not charging (the charging icon appears for a second and disappears), but this problem is not permanent.
The charging adapter starts working if I plug it to an other MacBook Pro, or after waiting for a while, or if an other charging adapter is plugged in.
Third-party service said that the problem could be caused with a faulty charging adapter and recommended to replace charging adapter.
I didn't replace the charging adapter yet, because I'm a little bit confused.
Please help me, what should i do? I don't know why my MacBook’s battery is swelled.
If you need more details, i can answer to your questions.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
2件の回答
Did you check if the battery is plugged in properly? and if your battery is showing up in macOS? If it is then it most probably is a battery issue.
If it does not show up in macOS then you might need to open the MacBook and check the battery connection!
Do let me know what you find out!
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
There is a couple of things I would do here:
These will allow you to see more clearly what’s happening with your system. I do have a few questions which might offer us some clues on whats happening.
  • You talk about having access to a second system what is it? Is the charger the same or different?
  • Are you using the original charger and the USB-C cabe that came with it or using something different?
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Ilyasbek Isabekov さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 3
過去 30 日: 4
今までの合計 243
