メインコンテンツにスキップ
27" display with 2560 x 1440 pixels resolution Thunderbolt & MagSafe cable attachments
160回答 すべてを表示
What is wrong with my screen?
Hello,
I have some damage to my screen and wondered if anyone could tell me what would need replacing to fix it?
It hasn’t been knocked or dropped and has just been sat on my desk for years and so I assume this is general wear with age. It looks like the LCD screen itself has degraded in part of the screen.
Thanks
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
1 件の回答
最も参考になった回答
This series has a sizable gap between the backside of LCD panel and the backlight reflector (the backlight LED’s them selves are mounted along the bottom edge).
I’m suspecting a critter got in and you are seeing the remains which settled at the bottom.
While you could open up the sandwich to get to it you might just want to see if you can get a small hole through the tape to aim a can’ed air snorkel to give it a quick blow to push it out of view. Don’t over do it and make sure you hold the can so no liquid is propelled out.
Or, just leave it alone.
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
Thanks for your suggestion, I'll give that a go :)
さんによる
コメントを追加
回答を追加する
joannavshaw さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 1
今までの合計 151
