メインコンテンツにスキップ
The Lenovo E330 ThinkPad Edge is a 13.3" stylish and durable laptop directed towards small-business.
9回答 すべてを表示
shut it down one day, and then I couldn’t turn it back on
So, I’ve had pretty much the same problem. My laptop was working perfectly fine, I shut it down one day, and then i couldn’t turn it back on. Here is what has worked for me. I’ve tried keeping it charging for multiple days and that doesn’t help at all, but if i leave it without charging and come back to it like a week later, it turns on perfectly fine like nothing has happened. What has worked every time is opening up the back of the laptop and removing the cable that connects the battery to the motherboard. I disconnect it, reconnect it, and everything works fine again. I don’t know what the actual cause for the problem is, but it seems the only way to reset it is to completely drain the battery down to 0% or disconnect the battery. Holding down the power button for 15 seconds doesn’t always work, but has a few times. At this point, I’m just going to buy a new battery for it and hopefully this will fix it altogether.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
3 件のコメント
Did buying a new battery help your issue?? I am in the same predicament.
さんによる
I am having the exact same issue, Has buying a new battery solve the problem?
さんによる
does changing the battery fix this problem?
さんによる
コメントを追加
1 件の回答
ベストアンサー
Hi @d2tizzle22,
If you have the Lenovo ThinkPad Edge E330 check if the backup battery is OK. This battery maintains the BIOS settings and can cause problems if it is flat (no pun intended as it is a coin cell type battery with leads attached ;-).
Here’s a link to the service manual for the laptop. Scroll to p.66-67 to view the necessary pre-requisite steps and then the procedure to remove the battery.
Here’s the part number for the battery : 02K7078 (I think)
You can double check on this page. You may be also able to verify the part number from the battery itself.
If you search online using the part number only in the search box of your browser, you’ll get results for suppliers of the part.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
d2tizzle22 さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 7
今までの合計 117
