メインコンテンツにスキップ
2015年3月にアップデートされたAppleのMacBook Pro 13" Retina Display Early 2015 はモデル番号はA1502、第5世代のIntel Core i5と i7プロセッサーが特長でForce Touchトラックパッドを備えています。
1185回答 すべてを表示
compatibility flex cable trackpad.
Hello everyone, everything good?
I need to change the flex cable for my MacBook Pro 2015 trackpad and I would like to know if the flex cables P/N 821-00184-A is compatible with P/N 821-00721-A
Can someone help me?
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
2件の回答
ベストアンサー
Here is the part you need for your system MacBook Pro 13" Retina (Early 2015) Trackpad Cable, Apple P/N 821-00184-A
I love Apples confusion in the way they manage their parts ID’s! Most companies keep the base P/N and then append a version ID. In your case that would to the letter A or other incrementing value.
But No Apple doesn’t do that! They just spin a new part number! So now which is the newest and which is the older version of the part?? Here’s all of the P/N’s for your cable.
923-01376, 923-00518, 821-00721 & 821-00184
Now the roman way would be to start on the left and make each version to the right be the newer (canonical order), Or if you where in China & Japan then the list would be in the reverse! The most left would be the newest! (non-canonical order) So confusing!
And that assumes the list is in the correct order what if its just any which way! The second being the newest or was it the third??
So any one of these should work! But don’t ask me which is the newest version ;-{
MacBook Pro 13" Retina (Early 2015) Trackpad Cableの画像
製品
$9.99
このアンサーは役に立ちましたか?
スコア 2
2 件のコメント:
Thank you very much, you explained it very well.
Here in Brazil I hardly find any information about it.
さんによる
@denisales - I spent my Christmas break with a friend who's family had a cattle farm São Paulo years ago when I was in Collage. We spent most of the time at the beaches. Had a great time, that was a long time ago!
さんによる
コメントを追加
@denisales looking at the connectors and location (schematic as well) of those, it will be possible to use either number to find the cable
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Denis さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 2
今までの合計 120
