メインコンテンツにスキップ
Wi-Fi付きの初代Apple iPadは16,32,64GBから選べます。モデル番号はA1219。修理は複雑な作業はなく、ヒートガンなどは不要です。
130回答 すべてを表示
iPad is disabled try again in 26,037,178 minutes
Okay so I have this iPad which I charged up today and when I unlocked it came
well what can I do as it is not connected to the internet, I cant erase the data and I don’t have the computer which I backed it up onto.
On the image you can tell its on ios 5 and does not have internet connectivity
I have seen all the posts about it but still I can’t fix it
Please help
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
2 件のコメント
Are you wanting the data off of it?
さんによる
Nope I don't want that
さんによる
コメントを追加
2件の回答
最も参考になった回答
There’s no easy way to remove it unfortunately - if it was that easy we’d have stolen iOS devices all over the market.
Your only option really is to restore it…
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
Hi
Connect it to any computer with itunes. Hold down the power button and home button at the same time. Once the screen turns black let go of power button and keep holding the home button for another 10 seconds. Your iTunes will detect a device in recovery mode. Hit restore and you should be set. Please be aware this will erase all data in your iPad and will require apple id and password when the restore is finished.
このアンサーは役に立ちましたか?
スコア 0
2 件のコメント:
Yes this might work but I am scared to do this because this iPad has been in cold storage for 2 years and it has a lot of important things in it so can I recover the data? Also the iPad is not being detected in iTunes
さんによる
One the iPad is disabled I don't think there's a way to get the data back sorry
さんによる
コメントを追加
回答を追加する
itsnotoranage さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 10
過去 30 日: 32
今までの合計 571
