メインコンテンツにスキップ
モデル番号はA1706 / EMC 3071ー2017年6月発売。この13インチMacBook ProはKaby Lakeプロセッサが搭載されています。最大4.0 GHzのTurbo Boost付き3.5 GHz Core i7です。
276回答 すべてを表示
Which one is the isight camera cable when I look at the board?
So my puppy hit the power cord at full speed and smashed my macbook pro 2017 with touchbar off the floor face down from a decent drop.
It turns on.. but it’s very very slow and the fans are going full tilt.
I found a thread on iFixit with a similar diagnosis and the thread suggested that the isight camera may be pooched and that the machine may be working overtime to try to connect to it (big paraphrase). The original post also suggested that when the individual disconnected the isight cable the problem was resolved (Albeit with no more camera)
I’ve reviewed the teardowns for this model and for the life of me I can’t find a shot that shows the placement of this connector under the hood.
I’m super comfortable tearing my machines down and have all the tools and patience I need. I’m just trying to avoid trial and error and am hoping someone can quickly point me to the right connector to try out.
Thanks in advance friends.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
最も参考になった回答
What you found was the older model FaceTime camera info, sadly the 2016 and onward MacBook Pro’s use a very different design! Here’s the breakdown of the cables:
You can’t leave the cable disconnected and the problem you face won’t go away with it being disconnected. Sadly, you’ll need a new display assembly to fix this - Sorry ;-{
Here’s the guide MacBook Pro 13インチ Touch Bar Late 2016のディスプレイアセンブリーの交換 and here’s the part MacBook Pro 13" Retina (Late 2016-2017) Display Assembly I’m sure you can replace the display!
MacBook Pro 13" Retina (Late 2016-2017) Display Assemblyの画像
製品
$454.99
このアンサーは役に立ちましたか?
スコア 1
3 件のコメント:
Thank you! Not ideal but at least I know where I go from here.
Cheers!
erik
さんによる
If you're set, don't forget to score the answer and accept it - Thanks! Sorry I couldn't give you an out.
さんによる
You saved my MacBook Pro 2017 from being useless. It was so slow, CPU 70-80%. I disconnected the camera and et voilà… Ready to go! I was freaking out, could see the problem. ALS was working, camera too…
さんによる
コメントを追加
回答を追加する
Erik Rubadeau さん、ありがとうございました!
統計データ:
過去 24時間: 3
過去 7 日: 5
過去 30 日: 49
今までの合計 2,052
