メインコンテンツにスキップ
Asus Screw Measurement Problem
So I’ve been servicing my laptop for about two years and I’m starting to worry about my screws being slowly stripped. I wanted to get replacement screws, but Asus won’t supply it to me and the European/American stores won’t ship/shipping is ridiculously expensive for such small orders. I’m trying to get replacement screws locally but I’m not sure which screws to get, since the screws listed can be quite confusing.
Here’s an example:
Asus SCREW M2*10L (4.5,0.8) (K) T5
Does anyone understand what it means? M2 is 2mm diameter, 10L I’m assuming is the length, T5 is Torx 5. What are (4.5, 0.8) and (K)?
Here’s another example:
Asus SCREW M2*3L (4.5,0.8) (K)+H #0
What’s +H #0?
Here’s one more example for good measure:
Asus SCREW M2*3L (K) B-ZN,NY #1
What’s B-ZN,NY #1?
The screws listed are here:
https://www.asusparts.eu/en/asus/noteboo...
It would be great if someone can translate all that into regular metric measurements.
Thank you.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
1件のコメント
Hi,
I think that B-Zn indicates the colour and the material of the screw, i.e. Black - Zinc. Try a magnet and see if they stick. If they do they're not zinc or maybe they're just zinc plated ;-)
I thought that I understood what (4.5,0.8) meant in two of your examples - screw head size and thickness of head but not really sure
As for the others I have no idea except maybe the #0 and #1 might indicate screwdriver size as they indicate for another that it is a T5 - torx #5. H = Hex perhaps IDK
さんによる
コメントを追加
1 件の回答
ベストアンサー
To be honest I’m not sure how you could be stripping your screws.
But stripping what they screw into is another matter
Size Example:
M8-1.0 x 20
M = Metric thread designation
8 = Nominal diameter, in millimeters
1.0 = Pitch (distance from thread to thread), in millimeters
20 = Length, in millimeters (see below)
I’m guessing this is all you need to know. These screw cost pennies.
Whether it is Torx or not doesn’t really matter. It is your choice. They just use Torx to keep the curious out
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
AAK さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 1
過去 30 日: 2
今までの合計 134
