メインコンテンツにスキップ
Appleがプロフェッショナルおよびパワーユーザー向けに提供するノートPCのラインです。現在、MacBook Proには13、14、15、16、17インチがあり、Pre-unibody(オリジナル)、unibody、Retinaディスプレイ、Touch Bar、SOC(システムオンチップ)設計によって大きな改訂が定義されています。
20007回答 すべてを表示
Spilled on my keyboard now the backlight won't glow?
I spilled wine on my macbook, cleaned it out quickly just by wiping it down then leaving it off over night, It worked fine the next day except my keyboard only lights up in the center. Would the apple store be able to fix this, my warranty is up though? There's no way I could take it apart myself without making it worse. And can any more damage occur from the wine or should my mac be okay except for the keyboard lighting?
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
1 件の回答
ベストアンサー
Without opening the case of your MacBook and taking a look inside it is impossible to know if the spilled liquid will cause you more trouble than the loss of the keyboard backlight. Any liquid entering an electronic device is likely to cause some havoc and the residue of any wine that might have made its way deeper into your MacBook's guts could cause corrosion and more trouble over time. If you are not feeling up to opening the case of your laptop to take a look, I do suggest you find someone to do it for you. The flow of electricity and any acidic wine residue will react with metal surfaces in internal connectors and just cause more problems. You may be lucky and the keyboard light is all that will go wrong. Depending on how much you are willing to risk you could just hope for the best and run with it, but not having someone look for more residue and letting it ride could make the computer a total loss. I'm not sure what the folks at the Apple Store would do. They might be willing to take a look, their official policy might be to turn you down but I have had a few pleasant and very helpful surprises at Apple Stores when I have had computer trouble on the road. They may have someone to recommend too.
To get a feel for what you would have to do to clean up the inside of your machine by yourself locate the disassembly guide for your particular MacBook here. For more about dealing with liquid spills have a look at the Electronics Water Damage page.
Unfortunately you are probably stuck with deciding if spending some money on prevention is worth it. I wish I could offer more than that. Good luck and I hope it works out.
If you are going to have someone take a look for you, do it soon and keep the computer off until then. The links above were suggested by ABCellars, many thanks!
このアンサーは役に立ちましたか?
スコア 4
1件のコメント:
+ I'd up you again if I could Jeff. You have given good advice and enlightened those less knowledgeable about the nature of the damages. Again, I welcome you to the ifixit repair forum.
さんによる
コメントを追加
回答を追加する
courtney さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 6
過去 30 日: 20
今までの合計 5,706
