メインコンテンツにスキップ
モデル番号はA1706 / EMC 3071ー2017年6月発売。この13インチMacBook ProはKaby Lakeプロセッサが搭載されています。最大4.0 GHzのTurbo Boost付き3.5 GHz Core i7です。
276回答 すべてを表示
CNW001 No Wifi hardware after screen replacement
Hello! First post here, wondering if anybody has any ideas…
I replaced the lcd screen assembly on my macbook pro, was not my first time doing and went well except when I powered on my mac i was unable to see any wifi networks. While trouble shooting i deleted the Wifi interface, which I still cant get back, but nothing seemed to work.
I decided to open back the mac and found one of the wifi/ airport adapter connectors was broken. I ordered a new part and put it in. Everything seems to be connected fine but still no fix. Reset PRAM, SCM and hardware diagnostic still shows code CNW001.
Any help is greatly appreciated!
P.S. When opening mac all the way there is a click noise. I imagine the wifi antena may not be seated correctly even tho everything is connected but anyone had this problem ?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
最も参考になった回答
Did you follow this guide? MacBook Pro 13インチ Touch Bar Late 2016のディスプレイアセンブリーの交換 ?
I'm suspecting you damaged the antenna plate (seen in Steps 25 & 26) or your WiFi/BT logic on the logic board is damaged.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
Connor Thomas さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 5
今までの合計 232
