メインコンテンツにスキップ
2020年5月発売の13インチMacBook ProはクワッドコアIntl 第10世代Core i5/i7プロセッサ搭載でIntl Iris Plus グラフィックス搭載(モデル番号 A2251/EMC 3348、4つのThunderbolt 3ポート)
71回答 すべてを表示
Is it more repairable / hardware upgradable than the MacBookpro 2019?
The MacBook Pro 13” 2019 model is said to be 2/10 repairable, which sucks because I want to upgrade my ram / core/ ssd storage. Is the 2020 version 13” easier to upgrade power and storage in the future?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
Well… Lets look at what you can’t upgrade in any of the newer MacBook Pro’s
  • RAM is soldered so what you buy is all you’ll get. Replacing the logic board is the only way to upgrade it which is just not economical.
  • Storage is now using discreet flash chips and the T2 chip as the controller. So you can’t alter the storage as in years past even though Apple did their own blade SSD storage solution (not following there M.2 standard). So again we can’t upgrade it after purchase either!
  • CPU hasn’t been upgradable in any MacBook or MacBook Pro! Again you’ll need to replace the logic board to get a faster CPU.
So from 2016 onward this has been the state of enhancement options internally, nothing is upgradable! The last upgradable system is the 2015 system but only the SSD. The last RAM upgradable system is the 2012 MacBook Pro unibody.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
vivianwoo96 さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 3
過去 30 日: 12
今までの合計 237
