メインコンテンツにスキップ
Repair guides and support for top and front loading Whirlpool brand washers.
425回答 すべてを表示
Power shuts off intermittently during a cycle
my power will shut off intermitently usually during the spin cycle. If I bang the front of the washer sometimes it will come back on again. Sometimes the spin cycle doesn’t completely drain when this happens and the cloths are soaked.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
2 件のコメント
Hi,
What is the model number of the washer?
Just verifying that the power turns off i.e. no indication on control panel of any power and not that the machine just stops operating?
さんによる
@jayeff YWFW9050XW01
Yes all lights go out and none of the buttons will respond
さんによる
コメントを追加
1 件の回答
最も参考になった回答
Hi,
Since you can make it happen when you bang the machine, it seems as though there may be a loose connection, which given that the problem is random then it may be occurring due to the vibrations caused by the machine operating.
I can only suggest that you disconnect the power from the washer and then access the control board to inspect the wiring from the power cord up to the board and also any harness cables that plug into the board, for loose connections etc. Also if the wires are crimped i.e. have crimped lug connectors on them, and are not screwed down onto a terminal, gently pull the wire from the back of the lug connector to see if it moves in the connector etc.
Unfortunately I cannot find a wiring diagram for your model but here are the parts diagrams that may help as they show where everything fits together, mechanically anyway.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
todd_archer さん、ありがとうございました!
統計データ:
過去 24時間: 3
過去 7 日: 12
過去 30 日: 44
今までの合計 770
