Why am I backfiring
My 93 Honda Shadow VT 1100 has sat for over a year I started her up it ran pretty good now it's backfiring really badly and running shity at lower speeds
I suspect your carburetor float valve is sticking. Ethanol gas is hygroscopic and causes severe corrosion as a result when it sits for periods longer than a month or two.
このアンサーは役に立ちましたか?
deltacstawy time to clean your carbs and while you are at it, get a carb kit to replace the parts that are gummed up.
過去 24時間: 0
過去 7 日: 1
過去 30 日: 1
今までの合計 58
