メインコンテンツにスキップ
Mac Proとして知られるデスクトップMacシリーズの2013年版新モデルです。
117回答 すべてを表示
Why my Mac Pro Cylinder Shuts down unexpectedly after few minutes (5)
Power on , ok, but few minutes shuts down
And I try to power on and nothing, only lights on ports like on video
If turn off, for a long time, turn on again, but some minutes turn off again.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
1件のコメント:
Have you tried running the onboard diagnostics to see if an error pops?
After letting the system sit awhile if it runs longer being cold, restart your system and press the D key to enter. tell us what the error code is.
Reference: Mac startup key combinations
さんによる
コメントを追加
1 件の回答
Without an error code to aim us it will be hard to diagnose what has failed. The likely suspects are in order:
  • Power supply
  • Failing capacitor on logic board VRM power logic which supports the CPU
The cause can be as simple as a power surge/bad AC cycle coming from your power lines. I strongly recommend a good UPS. Your peripherals likewise need to be sharing this UPS or if at a distance using a good surge suppressor outlet strip or its own UPS. As an example my internet modem is on its own surge suppressor as its located a distance from my desk with an ethernet cable connecting to my trash can Mac Pro.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Aarao Marins さん、ありがとうございました!
統計データ:
過去 24時間: 2
過去 7 日: 5
過去 30 日: 12
今までの合計 953
