メインコンテンツにスキップ
A portable Bluetooth speaker manufactured by Ultimate Ears.
60回答 すべてを表示
Megaboom 3 cannot downgrade demo mode firmware (v31.0.11)
I just bought a used Megaboom 3 which on arrival turned out to be a demo unit. I have read lots now about the demo units only being different due to the firmware version which disables bluetooth and requires a permanent USB cable connected to work.
Other people have been successful with earlier versions of the speaker in downgrading the firmware to the proper user firmware, but the apps I have are not working for this so far. I have the current version of the update assistant from the UE website which tells me the Megaboom is up to date (and has no option to thus do anything else), and an older app UE_1.3.91_x86 which does not recognise the speaker when the USB cable is connected.
Is there another version of the update app that will work with the megaboom 3 specifically and allow me to downgrade it please?
I’d be incredibly grateful as I was hoping to give this as a present. Thanks
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
3 件のコメント
I have the same problem and have been unsuccessful in fixing.
さんによる
Anyone still has the downloaded file for either windows or mac to roll back the update fro Megaboom3? If yes, can you share a dropbox or another link? The above posted links don't seem to work anymore.
Thank you
さんによる
Thanks a lot.
I dint have enough words to thank you.
It works perfect in my case with UE Megaboom.
さんによる
コメントを追加
5件の回答
最も参考になった回答
Hey Jim,
I found another Update-Assistent version 1.4.37.
This version is definitly working with the Megaboom 3.
(https://ultimateears.us2.list-manage.com...)
I had another problem and was able to fix my Megaboom with this version.
I would be happy if you could share with us your progress :)
Best
Vin
このアンサーは役に立ちましたか?
スコア 7
9 件のコメント:
Hey Vin,
After holding on to 2 demo units the link you provided was the only one out of many that actually helped the tool worked like a charm. Kudos to you.
Best,
Andrew
さんによる
thank you so much for this, looks like my demo unit is working as expected!! i really appreciate you taking the time to answer this :)
さんによる
Thanks! After searching for days finally works perfectly.
Really appreciate your kindly help.
さんによる
Joined to say thanks!! Was struggling with some previous versions of the software that wouldn't recognize the Megaboom 3, but this worked a treat!!
さんによる
Both my mac and windows machines are not picking up my speaker, do i need to do anything to get the pc's to detect it?
さんによる
4件以上のコメントを表示
コメントを追加
I think you need to speak with Ultimate Ears support to see what they say.
このアンサーは役に立ちましたか?
スコア 0
2 件のコメント:
Thanks, I did message them and gave very specific details of the software version I tried, the process, and the outcome of the software that it says it's up to date, and even gave the firmware version it's on etc, I. E. all the details needed.
They replied saying I should connect it to my pc and run the update assistant. Which means it ignored everything I said and was probably a bot detecting the word 'firmware' then sending a generic faq type response.
Not entirely surprising, but disappointing. I'll reply and chase it more. I know people have been able to downgrade earlier megaboom versions from demo firmware, but I cannot find the right software version to downgrade my one (a megaboom 3).
さんによる
Hello Jim, where you finally able to downgrade the demo model?
さんによる
コメントを追加
I was able to get this working on my megaboom 3 via the v3 edition of the UE update assistant app, great work everyone!
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
Thank you
さんによる
コメントを追加
Thank you
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
Seems to still be working
さんによる
コメントを追加
Thanks for the software link. My Megaboom wouldn't charge or turn on. Sometimes it did charge but power button didn't seem to work. I had previously checked the battery and it was reading 8vdc.
I downloaded the UE software here and my Megaboom was recognized. Mine had 31.5.23 and was upgradable. That updated it to 2.2.9 (3~4m) and then once that was installed, it started working again and the UE app took over updates from there and upgraded it to 2.4.16 via Bluetooth! Woohoo.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Jim さん、ありがとうございました!
統計データ:
過去 24時間: 2
過去 7 日: 5
過去 30 日: 60
今までの合計 3,656
