@teakdamar - I moved your question too its own as you have a 2012 model
Do you replace your systems SSD? What did you put in?
It does sound like your Hall sensor is messed up then. You’ll need to test it get a small rare earth magnet and a steel paper clip. You’ll also want a bit of masking tape (or Post-It note) to make a small pointer.
With the paperclip lets locate the magnet in the screens bezel face along the left side by sliding paperclip along. Once the paperclip is held by the lids magnet carefully fold the lid down and using masking tape marker transfer the location to the uppercase palm rest.
Now with the system running, slide the magnet slowly across the palm rest surface where you placed the marker. The display should turn off and when you go past the screen should wake up. Keep in mind the sensing area is about 8mm round.
Now to be clear, this is not instant! Did it react? If not, slide the magnet further to the front edge to see if the magnet was located in the wrong placement (the 2012 model has the magnet in a different location than the other models. If you locate it in a different place then your LCD panel was replaced and the person moved the magnet.
Hall sensor location:
7 件のコメント
From what you described here I think you have a different problem!
The Hall sensor senses the magnet held in the lid so when you close the lid the sensor fires off, at which point the computer knows to turn off the display and the keyboard backlight.
The test is just emulating the lids magnet to make sure the sensor works as well as the magnet is in the correct location as some displays have the magnet in a different location so it won't meet up with the sensor!
Dan さんによる
Do you have any more thoughts as to what it could be? I asked reddit and someone suggested that my magnet polarity is reversed.
Emren Akdamar さんによる
The Hall sensor only senses the magnetic flux it does not detect the fields direction.
How about posting a video so we can see clearly what you are encountering iFixitでの質問に画像を追加する方法
Dan さんによる
This is the video I attached to my reddit post earlier today. https://photos.app.goo.gl/5uxnHEwgDrLK6g...
Emren Akdamar さんによる
@danj Hall sensor?
amatsuda さんによる
2件以上のコメントを表示
