メインコンテンツにスキップ
The first-generation Trooper was available as a three- or five-door wagon with independent front suspension.
2回答 すべてを表示
Wipers getting stuck + motor drawing power
Hi, I have a 1984 Isuzu Trooper 3dr. Lately I’ve noticed that sometimes the wipers would randomly turn on when I started up the car and simply stop in a random position. Then I can’t get the wipers back down unless I pull quite hard on both of them.
The motor is drawing power as well (car had a voltage gauge for some reason) and it’s honestly irritating. I’ve replaced the wiper motor 3 times already and since it’s the rainy season over here I really don’t to be stuck without wipers in heavy rain again.
Is there anything I can do other than replace the motor yet again?
(As if anyone here actually knows about these 1st gen Troopers…)
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
2件の回答
最も参考になった回答
@ngs765 could be wiper linkage problem. If the linkage binds it will require more work from the motor and like you said a motor replacement does not permanently fix this. Check the linkage by removing the cowling just below the wipers.
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
I had suspected that since the passenger side wiper sometimes is out of sync. I'll try to fix that.
さんによる
コメントを追加
Often times the headlights must be turned on for the wiper cycle to complete. It was a safety design protocol from the late 70’s.
just a guess however.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
amatsuda さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 4
今までの合計 97
