メインコンテンツにスキップ
Huawei Honor 8はアンドロイドスマートフォンで、5.2インチ 1080pディスプレイ、RAM容量は4GB、12MPカメラセンサー、指紋センサー、USBーCポートが搭載されています。2016年に発売。モデル番号:FRD-L04
48回答 すべてを表示
Phone screen stays on for less than a second then turns off
My honor 8 started having screen issues today, but it feels like they are software more than hardware-based. When pressing the power/screenlock button the screen will flicker on for less than half a second (everything looks fine in this screen as far as I can tell) and then goes dark again. Pressing the lock button one more time doesn’t do anything, thus I guess this locks the screen again, but then after that further pressing the lock button repeats the above behavior.
I tried restarting the phone using the power button, power + volume up, power + volume down, power + both volume, but the result is always the same. Any ideas on what is happening here and what I could try to solve it? Should I just start looking for a new phone?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 2
2 件のコメント:
Hi Luca, I'm having this EXACT same problem. Did you ever figure this out?
さんによる
Hi Ole, in my case it was due to the light sensor on the front of the phone breaking. I'm still using the same phone with automatic brightness disabled and just regulating it manually. The tricky part was turning automatic brightness off, as I had only a second or so before the screen went black :)
Hope this solves your problem too!
さんによる
コメントを追加
1 件の回答
Your phone screen display may not be getting enough power, try charging the phone, if the screen stays on when charging but goes off when disconnected your battery may not be supplying enough power to the display. You may need to service it or replace it.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Luca さん、ありがとうございました!
統計データ:
過去 24時間: 3
過去 7 日: 20
過去 30 日: 73
今までの合計 1,025
