メインコンテンツにスキップ
iPhoneの第4代目で、修理はそのままパーツを直接交換するだけです。しかし、正面ガラスとLCDはセットで交換する必要があります。容量はGSM / 8,、16m32 GB / モデル番号 A1332 /本体カラーは黒と白色
2375回答 すべてを表示
Proximity sensor not working at all
A few weeks ago I dropped my iPhone 4 into my pool, but I recovered it in around 2 seconds and did the usual (bag of rice for a day, vacuum, etc. Now everything is working fine but the proximity sensor will not work in any situation at all. I don't have applecare, so I bought Zagg insurance that should cover it, but I don't want to be without my phone for 10 days, any suggestions?
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア -1
コメントを追加
1 件の回答
ベストアンサー
Liquid damage works in mysterious ways. Sometimes it completely destroys your phone, sometimes everything works, it is all about the luck of the draw. My guess is that the water has damaged either the sensor ribbon cable or the sensor connection on the logic board itself.
From experience i have found the sensor ribbon replacements do not work. I have used genuine apple parts for a few iPhone 4's with the exact same issue and the sensor just does not work full stop, which diagnoses the issue down to a faulty logic board due to liquid damage. If i were you i would just send it off to your insurance company and have to live without it for a few days, because i am sure that if you went about replacing the ribbon you would have your iPhone out of service for much longer.
Martin
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
回答を追加する
Andrew Martin さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 1
過去 30 日: 1
今までの合計 1,237
