メインコンテンツにスキップ
2018年3月に発売されたSamsungの新モデルの大型バージョンです。
130回答 すべてを表示
Can water short circuit a s9 plus or does the phone just need to dry.
My s9 plus got wet at the river.. was in a case and water got into the case. Maybe a minute or two max. the phone was turned off but tried turning it on’ after and it did. Switched it off back but then it didnt come on.
I let it air dry for almost 24 hours then put it in rice for about 10 hours. When I charge it’ the icon comes on but it flashes on and off and the green screen flashes on and off.
my question can water short circuit the phone or is it just the lcd screen probably needs changing?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
2件の回答
最も参考になった回答
Hi,
Here’s a description of the waterproof rating for the phone and what it means.
What you have to remember though is that is the condition that it left the factory in.
Its’ waterproof integrity after that depends a lot on how it was used (or abused) by the person who owned it. For example if it was regularly sat on (phone carried in back pocket of pants) or accidentally dropped once etc this could have slightly bent the frame or created a small crack which may have compromised its’ waterproof integrity.
You didn’t say how it got wet at the river, did it fall into the water? If it didn’t work after getting wet you would have to suspect that either the water caused the problem or if it did fall into the river, that the fall may have damaged something.
The only way to really know is to open it up and find out. Like most modern phones, the phone has liquid detection / liquid contact indicators inside the phone which will show when they have been in contact with water etc
Here are the ifixit Samsung Galaxy S9+ guides that may help with this.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
Review this guide: iPhoneの液体侵入ダメージの修理 to get an idea what’s now needed.
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
Not quite what I was looking for. Jus wanted to know if it’s possible that it could short circuit? And not be fixable
さんによる
コメントを追加
回答を追加する
Michael Dennis さん、ありがとうございました!
統計データ:
過去 24時間: 2
過去 7 日: 7
過去 30 日: 24
今までの合計 861
