メインコンテンツにスキップ
モデル番号A1311 / Late 2009 / 3.06 or 3.33 GHz Core 2 Duoプロセッサ
310回答 すべてを表示
No Power on Led 1 Green
So, a friend bring me this iMac and he told me that first it gave him trouble to power on, but he waited for some minutes and then it boot up fine. Now it does not power on at all.
So I take it a part, I clean it up (it was pretty dirty) and then I tried to power it on, nothing happened.
The Led 1 have a green light on, check the button and its OK, I short the pads and nothing happened, but it give me 12V in pin 11 of the test point (as it should when power on button its pressed) but still no power on.
I check the schematics and started testing the power rails:
S5 rails are on when unit has AC Power, I check all the S5 rails and they are OK
can´t check S3 nor S0 rails because they are on when logic board its power on.
Does anybody have any ideas?????
Thank you!
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
See if removing the GPU board alters things. I’ve started to encounter shorted out GPU boards.
このアンサーは役に立ちましたか?
スコア 0
2 件のコメント:
no removable gpu board, only a Nvidia chipset, printed on the board
さんによる
@annielservitec - Then your only option is replacing the logic board - Sorry
さんによる
コメントを追加
回答を追加する
Luis Anniel さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 9
過去 30 日: 11
今までの合計 122
