メインコンテンツにスキップ
Why does my power charger not charge my battery?
The charger is staying green when plugged in. The percentage stays at zero. I have reset the PRAM and SMC, but those resets have not helped. I removed the battery completely and reinstalled. Nothing is working.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
2 件のコメント:
Let's get a better idea on what your batteries health is. Install this gem of an app CoconutBattery Depending on your OS-X you may need an older version of the app, contact chris (at) coconut-flavour.com to get the needed version. Post a snapshot here for us to see iFixitでの質問に画像を追加する方法.
Also keep in mind your battery is likely just not working any more just do to age.
さんによる
I added the screenshot to my original comment. Thank you
さんによる
コメントを追加
1 件の回答
Well, not good the charging logic within your logic board has failed! You likely have one or two MOSFET’s blown.
This will require some delicate surgery to first test the MOSFET’s and then replace the ones that are damaged.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Kimberly Barkhurst さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 3
過去 30 日: 3
今までの合計 57
