メインコンテンツにスキップ
2015 Retina MacBook Airの修理情報とガイド。モデル番号はA1534
281回答 すべてを表示
Replaced battery but won’t turn on
Hey,
I have just replaced a battery for a customer but the MacBook will not power on.
i have followed all steps carefully and check them again but no success.
i placed the MacBook on a low voltage charge as you suggested, I reopened the MacBook and checked all ribbons and connections and everything is how it should be. The little light on the logic board for the battery power is on as well.
is there something I am missing?
Thank you
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 2
1件のコメント:
did you manage to fix this? im having the same issue, after battery replacement, macbook went dead. i can see the tiny LED lit up on the motherboard, but no chime, power, i can feel ir warm when charger is plugged
さんによる
コメントを追加
1 件の回答
From the info you have provided, it is highly likely you have a faulty battery. Here is a link to the Ifixit replacement battery: MacBook 12" Retina (Early 2015) Battery
Retina MacBook 2015 バッテリー の交換
MacBook 12" Retina (Early 2015) Batteryの画像
製品
$109.99
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Mark walker さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 2
今までの合計 52
