メインコンテンツにスキップ
Appleの第5世代スマートウォッチです。オプションでGPS + Cellularモデル機能があります。2019年9月20日発売。
49回答 すべてを表示
Display without digitizer stays black
I recently bought a series 5 with broken display glass. I was able to separate the broken glass and digitizer from the display succesfully.
At first I thought the display was broken after the separation since it stayed black. But at some point the battery died and suddenly the display showed the following image:
After charging for a while, the watch turned on and went into black screen again and stayed black.
I am currently waiting for the replacement digitizer to arrive, but I assume the series 5 is showing a black screen, when no digitizer is connected.
Can anyone confirm this behaviour?
Thanks
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
1件のコメント:
Did you ever figure this out?
I have a friend who has a series 5 that works fine, but the screen has two scratches.
How hard was it to separate the digitizer from the LCD?
さんによる
コメントを追加
5件の回答
If this is happening, there is either something stuck in the screen connector, the LCD cables are damaged, or one of the pins on the screen is bent out of place.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
My Apple Watch 5 was working fine. I took it off to take a bath and when I went to put it on my arm the display was black and showed the time only. I shows a red low battery but it was fully charged before. Any suggestions?
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
Hi, I have the same problem. Did the new digitizer help?
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
Did you finalize fixed the display? Or just replaced entirely by a new one?
さんによる
コメントを追加
Hi Franqus, I am having the same problem. Removed the glass (and by accident the digitizer) and now there is no image....
Did you manage to revive your Oled display?
Thank you
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
Same as @lucianolavigne . I stripped a part of the cable that connects the digitizer so I need to replace it. Can anyone confirm if the display should at least turn on if I remove the digitizer? I just want to see if it is working before doing/buying anything else.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
franqus さん、ありがとうございました!
統計データ:
過去 24時間: 3
過去 7 日: 8
過去 30 日: 10
今までの合計 822
