Laptop don't turn on
When I press the power button the power light blinks one time and no screen appears,
And if I press it 2 time the first it blink and then the light is ON for 10 second but no display and the light gets off again
この質問は役に立ちましたか?
この質問は役に立ちましたか?
Hi @bring_atharva,
If a power refresh or reseating the RAM doesn’t work , then there is a motherboard problem that would have to found.
Try to locate the motherboard schematics, by searching online for (insert motherboard’s “board number”) schematic, to hopefully find the schematics so that the motherboard’s power circuits can be tested
このアンサーは役に立ちましたか?
Disconnect power supply, take out battery and press power button for 15 seconds to discharge any power on the motherboard.
Disassemble:
Take out the coin shaped CMOS battery (bottom right in photo shown above) for about 30 seconds. Put back in clip.
Reassemble laptop but do not reinsert main battery.
Try turning on the laptop with just the charger plugged in. Does it boot up?
If yes the charger is good.
If no then the charger may be defective. If possible test with another charger of similar specifications.
If good with charger unplug charger put battery back in. Turn it on. Does it boot up?
If yes you are good to go.
If no then the battery probably is defective.
このアンサーは役に立ちましたか?
Hi @aactech ,
I supplied this same answer a couple of days ago and the OP said that it had already been tried several times and it didn't work, so I deleted my answer, but the OP hasn't updated the question mentioning that this had been already tried.
Cheers
Ta.
I will try it again in as u told, step by step as it is and then let's see what happens
@jayeff This process failed it didn't work and I am facing same problem
You can just try to check out these solutions for a possible fixing:
このアンサーは役に立ちましたか?
Hey, it's an laptop so there are not such wires as usually.
@bring_atharva You can just continue with other fixes, thank you!
過去 24時間: 0
過去 7 日: 4
過去 30 日: 19
今までの合計 655
7 件のコメント
Hi,
Can you hear if the fan starts?
Does it do this with the charger connected?
jayeff さんによる
Yes, it does same
Atharva Nikam さんによる
No, the fan does not starts
Atharva Nikam さんによる
Hey, ypu answer the question but it does not shows here.
Atharva Nikam さんによる
@bring_atharva
You said it didn't work so there was no reason to keep it there so I deleted it.
jayeff さんによる
2件以上のコメントを表示
