メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
2017年11月4日発売。モデルA1865、A1901。GSMまたはCDMA/64GBまたは256GB/シルバーまたはスペースグレイ。(発音は「iPhone 10」と同じ)。
Is my display original?
I purchased a used iphone X with cracked glass and no Face ID. I planned to replace with an OEM screen and could have done w/o the Face ID. But now I realize that even the true tone is missing. So is my display already a replaced one or is original? How can I make out this?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
If face Id and true tone are both missing the screen has definitely been changed. Unfortunately face Id is not repairable unless you have the original parts. It sounds like they tore the cable to the proximity/floor sensor and earpiece speaker. It possibly to repair that if you can find someone with the skills. The front camera and those sensors are paired to the motherboard and if one is damaged or changed then you are out of luck. Unless you want to trade it for a refurbished one from apple and pay a few hundred dollars. But if you can find a repair shop that has the correct equipment you can get true tone back.
このアンサーは役に立ちましたか?
スコア 0
2 件のコメント:
Thank you for the answer. The rest of the phone is working well but even the auto brightness feature is missing and does not work. No 'replaced display' message in the settings as well. Just cracks on glass and dents around the earpiece area, can dropping the device cause all these issues?
さんによる
It's a small possibility but the iPhone X will not show that the screen has been replaced. That feature if you want to call it that didn't start putting up that message until the iPhone XS.
さんによる
コメントを追加
回答を追加する
Nitesh Rathod さん、ありがとうございました!
統計データ:
過去 24時間: 3
過去 7 日: 6
過去 30 日: 24
今までの合計 117
