Lights don’t go on when door is opened or closed
Lights don’t go on when garage door opens or closes
Update (07/20/2020)
Light bulbs are fine
You're going to have to get a multimeter and start tracing this problem. Ours have relays that click on and off and if yours does, but it doesn't click, there's where to start looking. If you're not good with 120 volts, don't touch it unless it's unplugged.
このアンサーは役に立ちましたか?
If it doesn't go on even when the light button is pushed, you may want to check the bulb first.
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 2
過去 30 日: 4
今までの合計 84
