メインコンテンツにスキップ
9月20日に発売された、Appleのメインストリームとなる2019年iPhoneモデルには、6.1インチLCDタッチスクリーン、デュアルカメラが搭載されており、6色から選べるカラーセレクションです。iPhone XRの継続モデル。
iPhone 11 REBOOT LOOP - THERMALMONITORD
Dear all,
I have some trouble with my iphone 11, this one reboot 2 or 3 minutes after starting. If i don’t use it after the starting, this one doesn’t reboot…. (I have replace the rear glass this one worked fine before replacement)
I try to :
Restore and Update iOS : No result !
Try to disconnect all accessoiries on the logic board : No result !
When i go to the log files, it look like one of the sensor is missing and make the phone reboot !
reason" : "(1 monitored services unresponsive): checkin with service: thermalmonitord returned not alive with context:\nis_alive_func returned unhealthy : current 3fe3bfffffffffff, mask 1ffffffffffff, expected 1ffffffffffff. Missing sensor(s): mic2 \nno successful checkins since wake (120 seconds ago)",
Do you know where is the sensor ? « MIC2 » Wich flex need to be replace ?
If you want i can share you the log files.
Thanks in advance,
 Best regards
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 8
5 件のコメント
I have same issue .Replaced power flex checked the microphone, it is working fine but mobile restarts after 120 seconds.Did your problem solved after changing lighting connector ?
さんによる
I had this issue the only way to fix it is to replace it with an original cable from another phone, these part replacements you use from China won’t work. Depending on the error you either need to replace the power button/flash light flex or the charging port
さんによる
Thanks man , I had the same log " Missing sensor(s): mic2 \nno successful checkins since wake (120 seconds ago) " I used china power button /flash/mic flex and issue is not resolved yet.I think that would be the issue in my case.
さんによる
Replaced power button flex cable and all goes well and my error was: Missing sensor(s): mic2
さんによる
Mirko Cavasino did you ever resolve this problem ?
さんによる
コメントを追加
7件の回答
ベストアンサー
I finally found the problem by myself. This trouble have done by the lighting connector (Damage during the rear glass replacement) I have bought new one but not original : SAME PROBLEM. I finally bought original cable : Everything work as well !
I you have this problem bought original flex cable ….
このアンサーは役に立ちましたか?
スコア 3
6 件のコメント:
hey, can you do me a favour? take off the lightning connector and boot, then check what sensors are reported missing. I keep getting "missing sensor(s): Prs0" but I don't know where Prs0 is, already got a new $100 battery but that didn't fix it, prs0 is still reported as missing
さんによる
Did you find a fix ? I am getting prs0
さんによる
PRS0 is Pressure Sensor which is on Charging port. Charging port must be connected when powering on... it will not pass check and reboot after 180 sec
さんによる
Hello I have this same probably. Can I Know the exact part you replaced. I mean the name as I would like to purchase it.
さんによる
Original parts speically power button and charging both must be connected to avoid restart iphone 11 after 2:55 sec or 3 mints spent a day to figure it out
さんによる
1以上のコメントを表示
コメントを追加
Mic 2 is the power flex cable.
Mic 1 is the charging port.
Simply removing/unplugging will still give the same error (missing sensor) because it is missing if it's unplugged.
Youll have to replace with a genuine pull, or high quality replacement.
Open the phone, plug the new power button flex to test, then install.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
Iphone 11 Same issue i got and its second one after simple glass replaced by leiser machine was done and now restart after 2:25 sec i have replaced charging block with an original one twice still restarting flash light got damdge by removing the glass i tried original flash light aswell still same stuck now any can suggest a solution which work rather than do this and do that becoz i have done eveything else i dont want wipe the phone unless its last resolt
Thanks
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
I did figure it out iphone 11 restating after back glass replacement i damdge the flash light and i was using the copy one and that's was my issue i used an original part and it worked but when you do test it power button+charhing block Both MUST be connected either of not connected phone will restart so what ever who ever got this issue do the same POWER BUTTON +CHARGING BLOCK BOTH must be connected
さんによる
コメントを追加
I just had this same issue with a water damaged iPhone 11, panic showed error on sensor prs0 but the problem was in the volume flex due to rust and shorted i2c1 lines in the same connector.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
I have this same issue that shows mic2 missing sensor any idea on how to resolve it your help would be much appreciated.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
I encountered a similar problem, the rear glass damaged the flash and had to restart the problem. I have replaced a genuine manufacturer but the problem cannot be solved. My phone still reboots. does anyone have another guide to help me? thankS
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
its the power button or chrging port neither motherboard issues
さんによる
コメントを追加
Hey Guys I got a similar Problem. I changed the damaged Backhousing with a cheap one (China, pre installed Lightning+Power+Louder+Antenna Flexes) of a Iphone 11 and got the same issue, restart after 180sec.
In the Paniclog there was the missing sensor Mic2. So I bought a Original Power-Flex from ebay, but this was not the solution. Could the new one also be faulty?
Should i also replace the other pre installed flexes? Or could it be the Motherboard?
このアンサーは役に立ちましたか?
スコア 0
3 件のコメント:
I had the similar problem still currently going on. My phone got seriously water damaged and they replaced the camera, board, speaker flex and screen and it still keeps rebooting, how is this gonna be rectified?
さんによる
@Shian Ramdial, what error are you getting in the panic log? You need to identify which sensor is causing the reboot before you can determine what needs to be fixed.
さんによる
I believe they think it’s the power button flex what’s causing the rebooting
さんによる
コメントを追加
回答を追加する
rossi さん、ありがとうございました!
統計データ:
過去 24時間: 5
過去 7 日: 39
過去 30 日: 177
今までの合計 39,459
