I cant able to unlock the ipad mini
ipad mini (wifi ) screen is locked and cant able to unlock -sliding menu is not working.Please support here to solve this
Did you try restarting Press and hold the power button and then use the slide off. If you can’t do that that tells me your touch logic is damaged and you either need a new screen assembly or the logic board has damage.
このアンサーは役に立ちましたか?
Thanks you buddy I can’t do that so I need to go for a screen replacement.
過去 24時間: 0
過去 7 日: 1
過去 30 日: 3
今までの合計 54
