メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Nintendo 2DSは、Nintendo 3DSのエントリーモデルとして開発された携帯型ゲーム機です。ハードウェアはほぼ同一ですが、3D上部画面機能は搭載されていません。
My 2ds doesn't charge
Hi guys, a friend of mine gave me his old 2ds that does not turn on, i thought it would be a problem with the power connector. But, using a multimeter i can see that the 4.6 volts reach the pins that go to the motherboard from the back of the connector. I charged the battery with an external adapter and the console works correctly, could someone help me to check any of the components that may be damaged? Or do you know where I can get a point-to-point guide to know where the motherboard should have voltage? Thanks!
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
1件のコメント
Hello guys,
I have the same issue, charging light come on for a short time and gone.
My battery is good (tryed it on another 2ds and works fine)
Did you manage to fix the issue ?
Thanks
さんによる 共有
コメントを追加
1 件の回答
最も参考になった回答
There are two fuses on the board. One right next to the charging port and one beside/half underneath the wifi module. Marked F1 and F2. Some people say it's a shot filter coil (the square block next to the port with four pins), others say it's a broken charging IC.
Does your charging light come on for a short time or isn't it showing anything at all?
I have the same problem right now.. There is voltage on the fuses and on the charging pins but it doesn't want to charge the battery..
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
Did u guys solved? i hace same... and i have another that CHARGES but it doesnt turn on at all (neither blue led)
さんによる 共有
コメントを追加
回答を追加する
er307_sp さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 35
今までの合計 549
