メインコンテンツにスキップ
The HP Spectre x360 13 -ac023dx is a compact laptop which is light, powerful, and has smart security features.
6回答 すべてを表示
2017 Spectre x360 back panel removal?
Im trying to remove the rear panel from my 15' x360 to upgrade the ram. I took out all the visible screws but then also knew there were supposedly screws under the back feet, however i tried pulling off the rubber feet and under was this, pictured below. the feet were on with adhesive and these plastic pieces are on help on very strongly. Ive tried prying with all sorts of tools but cant get them to move. I Dont see what im seeing in any online guides so im a bit confused. How do I get these off? PS. the selected device is not my exact model, but the closet I could find in the device list. Thanks!
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
1件のコメント
Do these maybe unscrew or do you have to pry them open?
さんによる
コメントを追加
1 件の回答
最も参考になった回答
Hi,
Here’s the maintenance and service guide for a HP 15 x360 laptop. You don’t state the full model number but this manual is dated 2018 so hopefully it should be OK
Go to p.30 to view the necessary pre-requisite steps and then the procedure to remove the bottom cover.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
Ethan Hall さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 4
過去 30 日: 12
今までの合計 1,440
