メインコンテンツにスキップ
Google Pixel 2は2017年10月17日に発売されたgoogleの第二世代モデルです。このスマートフォンは5インチAMOLEDディスプレイと64もしくは128GBの容量オプションがあります。3色のカラーバリエーションがあり、Just Black、Clearly WhiteもしくはKinda Blueから選べます。
70回答 すべてを表示
Is it worth trying to fix smoking pixel 2?
I had a pixel 2 which started failing to take a charge a couple days before it completely failed on me. I was running the Android ten beta and kinda thought maybe that was the problem, so when I took it off the beta and reset it, and the phone started charging again, I thought I had solved it. It stopped taking a charge again and all of a sudden I smelled something burning, I took the cable out and sure enough the smell came from the port. I took it for a repair and told them that I smelled smoke, but this time when they plugged it in it really started smoking and they told me to take it up with Google. Unfortunately I bought the phone off a reseller on eBay, and it had almost been a year since the purchase, so not much I could do. I of course have another phone now, but stumbled across the phone while cleaning and was wondering if I should bother repairing it myself? What could the problem have been, battery, charging port, or is there probably some amount of damage not worth tinkering with?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
最も参考になった回答
You can buy a used one for 80 dollars so in my opinion it's not worth fixing.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
Victoria Lopez さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 2
過去 30 日: 4
今までの合計 276
