メインコンテンツにスキップ
1998年に発売された任天堂ゲームボーイのカラー版です。このデバイスの修理は難しくありません。
74回答 すべてを表示
Game shark and Pokemon silver
I used game shark on my Pokémon silver and at first it was working perfectly got unlimited master ball and the first Pokémon code I put in worked caught it saved and hit button on game shark to go back to gameshark menu and put different Pokémon catch code in and once I tried going back to the actual game the screen just went blank(white)
so I turned off consol took game out of the gameshark and tried just the game without the gameshark and now it’s just white and game will not work at all….
any ideas on how to fix?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
2 件のコメント
It’s not tht the game won’t save its the whole game won’t even work doesn’t even get pass the start up screen it’s does the Nintendo start up screen then just goes blank
さんによる
@vactac101 See my update.
さんによる
コメントを追加
1 件の回答
最も参考になった回答
The problem with devices like the Game Shark is they do mess up save files beyond repair if you use conflicting codes - generally, once you damage the save there’s not much you can do but start over. Pro tip: Have two saves when you use cheat codes.
If the game doesn’t want to load, the save you did it on is so corrupt it cannot boot. Refer to this guide to open the cartridge, remove the battery and replace it. Run it without the battery to be sure the saves are gone. However, it may be possible to erase the saves by doing it before the game loads.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
John vac さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 13
過去 30 日: 38
今までの合計 887
