メインコンテンツにスキップ
2017年3月に発売された第5世代iPadのWi-Fiのみのモデルです。9.7インチRetinaディスプレイと64ビットA9プロセッサーを搭載したモデルで、32 GBおよび128 GBのストレージオプションがあります。
101回答 すべてを表示
No click response from home button.
Hi.
I often find that the home button for the ipad 5 needs to be replaced because the click mechanic does not work after being transferred to a new screen. The button does not appear to be damaged and the click mechanic does work if I press on it with a spudger, however once I place the bracket in place it will not click, or only slightly. If I replace with an aftermarket, everything works and the click is solid.
Note I have repaired multiple tablets so I have some idea what I doing but I cannot figure out why this happens unless its a fault with the button.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
The problem is the thickness of the glass, the adhesive used on the home button (HB) bracket and the distance between the black dot on the HB actuator and the bracket.
I use Tesa 4695 or 61395 (red DBL sided transparent adhesive tape equivalent works too) for strong adhesion for the bracket to the digitiser glass. Replace the actuator if needed if the black circle dot is missing. Same HB should be reused due to touch ID.
Sometimes depending on if the HB feels dipped in you may need to bend the bracket closer to the home button on the middle of the bracket.
Then to finish it off use B7000 / T7000 liquid glue on the sides of the bracket and some on the sides of the HB black rubber gasket to ensure the HB stays snuggly on place.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Stuart さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 1
過去 30 日: 2
今までの合計 565
