メインコンテンツにスキップ
Apple Watch Series 2は2016年9月7日に発表され、同年9月16日に発売されました。
132回答 すべてを表示
Apple watch Series 2 - adding adhesive to force touch gasket
Planning to replace the screen as well as the force touch gasket.
I’ve read some reviews saying that adhesive on some force touch gaskets don’t stick the screen to the case really well. Will adding more adhesive to the top and bottom of the gasket allow the screen to still fit flushed to the case?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
最も参考になった回答
The gasket is not intended to be ridged! It needs to flex as within it is a sensor so the watch knows it was touched.
I personally haven’t had any issues when I was fixing the watch (I don’t any more). The issue I’ve have seen is people not cleaning the surfaces properly as well as touching the gasket adhesive.
Any oils or dirt on the surfaces will cause the part not to adhere properly. Make sure you are using reagent grade solvents.
The other issue is an old gasket which is not properly sealed can have its adhesive dry out.
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
Thanks for your response! very helpful. Was wondering if it still keeps some of its water resistant capabilities?
さんによる
コメントを追加
回答を追加する
Khanh Nguyen さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 3
過去 30 日: 4
今までの合計 63
