Error report poppin up when power on
My Epson Et-2720 was down for a duration of 3 month due to covid-19 and when I do power it up it showing error report any answers?
First, check and see if all cables, connectors, etc. are properly conected. Second, your software may need updated, or the device it's connected to needs the same. Third, the hardware of the printer and device may have an issue. If the text reads, “Printer in error state", there's a bigger problem in the printer itself. Fourth, check paper/ink/cover closed/jammed. Outside of that, you might need a technician. Happy trails.
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 0
過去 30 日: 1
今までの合計 104
