メインコンテンツにスキップ
2014年9月19日に発売されたiPhone 6の修理情報とガイドです。モデル番号 A1549、A1586、A1589。
4994回答 すべてを表示
Is this iPhone Completely dead?
Been given this iPhone to fix, they said the kids play with it a lot pulling out the charger before it’s charged fully if it’s been like ten minutes they’ll take it off I resulted it into a battery problem or charging port as it don’t show it’s charging as I try turn it on nothing no vibration at all no light did a test run for a new charging port again nothing also did a new battery Testing still nothing the screen don’t seem cracked in anyway it’s unlikely to be the screen really stuck on this one
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
Try hooking up a known good battery and chargeport (as well as the screen you have), plug it in and give it a few mins to boot. Once you’ve given it enough time to boot, try plugging it into a computer to see if the computer detects it.
If the phone is detected but the screen is still black it could be a faulty screen, or the phone is in DFU mode. If the phone is in DFU mode, when you open iTunes you will get a message saying “iTunes has detected an iPhone in recovery mode. You must restore this iPhone before it can be used with iTunes”. To exit DFU mode, simply hold the lock and home button down simultaneously until the phone reboots, or if you don’t mind losing the data, click restore in iTunes. If the screen still does not show anything after this, the screen is probably to blame.
If your computer doesn’t detect the phone there might be bigger issues. With plugging/unplugging the device it’s possible that the charging IC was damaged, in which case it would need to be brought to a repair centre for microsoldering.
Hope this helps!
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Chloe jayne さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 1
今までの合計 59
