メインコンテンツにスキップ
2017年9月22日発売。モデル番号はA1864, A1897。GSM もしくはCDMA/容量は64もしくは256GB/仕上げはゴールド、シルバー、スペースグレイ。
678回答 すべてを表示
need glue for iPhone screen frame repair
hello for all please tell me a name for a powerful glue to fix the break for my iphone frame as it shown on the picture
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
5件の回答
最も参考になった回答
Should buy a new case for the phone. You can purchase them with small parts like the switches or you can get fully loaded with the antennas, charging port, tapic engine, and speaker installed in it. I don't think you are going to get the frame to last because it's metal. The only type of glue that would work is possibly jb weld. You would have to disassemble the phone to try and glue it so you might just change the case. You could also buy a used iPhone that is iCloud locked and change your motherboard and home button.
このアンサーは役に立ちましたか?
スコア 3
2 件のコメント:
Although you can buy aftermarket frames for less, I've had poor experiences with them.
さんによる
@hootonberg I also recommend buying a iPhone that's iCloud locked and switch the motherboard and home button. I also have found new rear case/frames in china with Apple original case/frame. I will let you know what the supplier is you are interested
さんによる
コメントを追加
I wouldn’t use glue to fix that. You’ll have to disassemble the whole phone to avoid getting it in places where it shouldn’t. At that point I would just replace the frame.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
I suggest just replacing the frame, you’re going to have to take everything out to glue it any even if you do, there is a very low chance it will hold up because of the location,
While ifixit doesn’t sell these you can surely find one from someone else or find a dead unit and salvage the frame
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
the problem is no shipping from china to israel these days and I bought a mobile from ebay on march and until this moment it had not arrived so i am trying to find a solution
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
Have Ebay return your money. Do you know anyone in the us that could buy a locked phone and ship it to you. And the supplier I am referring to is in Hong Kong if that makes a difference
さんによる
コメントを追加
but can you please suggest me a name of powerful glue ???
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
tamer さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 3
過去 30 日: 5
今までの合計 207
