need glue for iPhone screen frame repair
hello for all please tell me a name for a powerful glue to fix the break for my iphone frame as it shown on the picture
Should buy a new case for the phone. You can purchase them with small parts like the switches or you can get fully loaded with the antennas, charging port, tapic engine, and speaker installed in it. I don't think you are going to get the frame to last because it's metal. The only type of glue that would work is possibly jb weld. You would have to disassemble the phone to try and glue it so you might just change the case. You could also buy a used iPhone that is iCloud locked and change your motherboard and home button.
このアンサーは役に立ちましたか?
Although you can buy aftermarket frames for less, I've had poor experiences with them.
@hootonberg I also recommend buying a iPhone that's iCloud locked and switch the motherboard and home button. I also have found new rear case/frames in china with Apple original case/frame. I will let you know what the supplier is you are interested
I wouldn’t use glue to fix that. You’ll have to disassemble the whole phone to avoid getting it in places where it shouldn’t. At that point I would just replace the frame.
このアンサーは役に立ちましたか?
I suggest just replacing the frame, you’re going to have to take everything out to glue it any even if you do, there is a very low chance it will hold up because of the location,
While ifixit doesn’t sell these you can surely find one from someone else or find a dead unit and salvage the frame
このアンサーは役に立ちましたか?
the problem is no shipping from china to israel these days and I bought a mobile from ebay on march and until this moment it had not arrived so i am trying to find a solution
このアンサーは役に立ちましたか?
Have Ebay return your money. Do you know anyone in the us that could buy a locked phone and ship it to you. And the supplier I am referring to is in Hong Kong if that makes a difference
過去 24時間: 0
過去 7 日: 0
過去 30 日: 4
今までの合計 202
