Touch Bar does not respond after screen replacement
2017, A1706 with Touch Bar . ID touch works fine, Touch Bar still show information as nomal, but there is no respons when I touch it. There is TouchBarServer in the activity monitor but no Touch Bar agentin. 1, I tried 1,Open Terminal application and run command killall ControlStrip. 2, Open Terminal application and run command sudo pkill TouchBarServer. 3, Tried to reset SMC and NVRAM. 4, I updated the system to Catalina. No one works for me…
Anyone could help? Thanks!!!!
Did you check the logic board connection?
Dan さんによる
No, I didn't, could u tell me what area should I check on logic board?
Roy さんによる
