メインコンテンツにスキップ
iMac Intel 27インチ EMC 2309 (Late 2009, Core 2 Duo 3.06もしくは3.33 GHz) ID iMac10,1, EMC 2374 (Late 2009, Core i5 2.66 GHzもしくは Core i7 2.8 GHz) ID iMac11,1
20回答 すべてを表示
Why is my iMac still running but the screen is off?
My iMac late 2009 is running like applications and such will open but the LCD screen is black.
I have put new thermal paste on the GPU, I have made sure all cable connections are tight, and I have even recalled the GPU solder.
One thing I might think is causing it is that the GPU temperature cable is unplugged because its being a pain in the but to install. But, I’m not sure it is that because I have my fans running at high speed because HDD temp cable is unplugged because I recently upgraded to a SSD.
Any answers are greatly appreciated.
Thanks
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
Are you able to see an image on an external display? If you are then the GPU is fine. This then points to your internal display having issues. Using a flashlight placed on the display at a sharp angle can you see the faint image off your desktop and its icons?
You need to fix the fans, you really need to get them connected and working. Here’s what you’ll need for your SSD OWC In-line Digital Thermal Sensor for iMac Late 2009 - Mid 2010 Hard Drive Upgrade
このアンサーは役に立ちましたか?
スコア 0
2 件のコメント:
I don't have an external display currently or at least one with a mini display port, what can I do?
さんによる
A HDMI or VGA monitor will do using a dongle.
さんによる
コメントを追加
回答を追加する
Reece Clegg さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 2
今までの合計 59
